Wiring Sail Subs in Camaro
Hey,
I just received the KEE audio replacement speaker package for my 99 Camaro with the Monsoon system.
The Bazooka speaker says it's 4 ohms....I thought I read on here that the Camaro sub is 2 ohms.
Before I install these, I assume that the subs have to be wired on each speaker in parallel to get to the factory 2 ohm spec?
The rest of the install seems pretty painless.....
Thanks in advance for the help!
Hi, I addressed this awhile back but it was on another post. Check out post #7 for the actual diagram (for this it is the top left diagram specifically). They are DVC 4ohm so you just wire them in parallel. Takes about 5 minutes and 12" of speaker wire, 6" for each side if that. Hope this helps you!!
https://ls1tech.com/forums/stereo-el...ack-stock.html
Thanks for the help!
