step by step guide for speaker install?
I got my speaker now i just hafta install it. Its the speaker behind the drivers seat. Is there a site that shows a step by step guide to install it??
my instructions were assuming you have the proper speaker for the Trans Am Monsoon amplifier. What speaker are you currently trying to put in there, it isn't a best buy special is it? The stock speakers are 4ohm dual voice coil. If you have a 4ohm speaker you could just use one pair of wires but you will only get half the power to the speaker. I say, return the speakers and get the correct replacement.
the bazooka 6.5" subs from keeaudio.com could be a nice choice.
It was from best buy. Its some sony. I'm going to go ahead and get those subs from keeaudio. Once i get them how do i hook them up? Do they have two positive/negative connections on it?
Save the manuals!
Once you get a DVC speaker; this thread has some points for an install: https://ls1tech.com/forums/stereo-el...ll-w-pics.html
The installation of the thread above is extreme. (Most people re-use the old wiring harness and many just use self-tapping screws to make new mounting holes.) However; you should pay special attention to the point about washers on the screws.
