???headlight PROBLEM.....
Old 02-02-2009, 06:51 PM
nemss1's Avatar
Question ???headlight PROBLEM.....
cut the red-orange wire behind the switch and removed the wire and also removed the ambient light sensor and spliced the wires together and when i turn the headlights on, all 4 turn on passenger side dimmer than driver side
could it be electrical like battery or alternator? couldnt see why it would be the alternator tho. car isnt running at the moment
Old 02-03-2009, 07:21 AM
Ungrounded Moderator
WhiteBird00's Avatar
Why would you cut the red/orange wire? And do the lights go back to normal when you reconnect it?
Old 02-03-2009, 12:37 PM
nemss1's Avatar
cutting the wire will disengage the auto lamps. its in the FAQ sticky in this forum. i havent re-connected it because i dont remember where it ended up after the switch
Old 02-03-2009, 03:44 PM
The reason I asked is because shorting the light sensor wires disables the automatic headlights - so why cut wires?
I recommend reconnecting the red/orange wire (just splice the cut ends back together) and checking if your problem goes away.
Old 02-03-2009, 05:04 PM
nemss1's Avatar
just decided to do away with the wire while removing wires for the body harness mod. do u know where or what module the red-orange wire plugs into???
Old 02-03-2009, 05:17 PM
There are two red and one orange wires at the headlight switch. One red provides constant (battery) power from a fusible link. The orange provides constant power from the TAIL LPS fuse. And the other red wire goes to the DRL module behind the radio.
Old 02-03-2009, 05:32 PM
nemss1's Avatar
i should be more specific. the red-orange wire came from pin G behind the switch. where does this wire end up?
Old 02-03-2009, 05:55 PM
That wire goes to position D of the black 8-pin connector at the DRL module.
Old 02-03-2009, 05:58 PM
nemss1's Avatar
thank u. would cutting and removing that wire cause my problem?
what fuction does that wire control?
Old 02-04-2009, 05:48 AM
That wire provides power to the automatic headlight relay inside the DRL module. I can't see how it would cause the particular symptoms you describe but when something goes wrong immediately after a modification, it's best to undo the mod first to confirm it didn't cause the problem.
Old 02-04-2009, 12:52 PM
nemss1's Avatar
thanx whitebird
Old 02-04-2009, 05:20 PM
nemss1's Avatar
hey man, i think i found my problem. when i was doing the body harness and engine harness mod, i pulled the LH and the RH wires in the underhood fuse box. do u have a diagram for the juntion boxes under the hood? or know which wires to re-connect?
note*my car came with fog lights but i did away with those. probably why i accidentally pulled the LH and RL wires because i think they were inter-connected with the red wire
Old 02-05-2009, 10:22 AM
nemss1's Avatar
figured out the prob whitebird. had a short with the headlight wires that run under the fuse boxes under the hood. again thank u for helping
