alarm problem
alarm problem
I have a 98 z28 with stock keyless entry alarm. just recently when i lock the car either by remote or by locking it internally, i would normally have 2 honks+lights blink, and just the lights blink when locked internally. for some reason now when i lock it either way it does what it's supposed to do normally, but in addition, about 5secs after i get 2 loud honks, as if the alarm is going off. does anyone know why this is doing it all of a sudden?
The alarm going off just after arming is usually a shock sensor issue. Don't know why you're just getting 2 honks though. I'd try unplugging the shock sensor in the spare tire area and see if it stops. Take a look inside it for signs of water intrusion too.
yea it happened again last night,this time it had been locked for atleast 2hrs.
i hear a honk outside, then another, then it kept honking. i used the remote to unlock then lock again. Then 15mins after it did the same thing, so i just locked it manually with the key. ill check the shock sensor and ill give uguys an update.
