How do I get door panel off?
Yes you do, no way you are going to easily get the speaker out without removing the door panel. 3 long bolts on the arm rest, one bolt next to the door lever, unplug the harness behind the window, door lock buttons, and light, remove the manual door lock switch, remove the one screw from the triangular trim piece and remove, lift up on the door panel and then pull out. Its pretty easy.
