Turn signals acting VERY strange
About two weeks ago I replaced both front turn signals bulbs because they were out. Everything worked perfect ever since. Two days ago I flip my turn signal and the indicator comes on and won't blink it just will start to dim and then go out....this is also what my turn signals are doing. It almost seems that there is a bad ground or something. Any ideas guys??
Ungrounded Moderator
Time to change your blinker fluid. http://kalecoauto.com/index.php?main...&products_id=6.
Also, check that the front sockets aren't melted or corroded. That could cause the symptoms you describe.
When I changed the two front bulbs, of course they burned but not corroded. I use the electronic "jelly", can't remember the name....in order to prevent this and create a good connection...
The flasher is clipped to the back side of the dash panel just to the right of the opening when you remove the knee panel under the steering column. It is a thermal/mechanical device somewhat like a household thermostat so a failure doesn't always mean no function - sometimes the failure will be intermittent.
Man, you are my mother flippin hero. NO ONE has ever been able to come up with a diagram of where this thing is.....GM even had problems telling me where it was. Thanks a million.
