Amps, subs, and speaker help!!!
I have a 1994 Firebird with over 200K miles. I plan on getting a new car in a few years, so I am putting in speakers, because they can be removed. I replaced the rear speakers with Rockford Fosgate 3 way components. They are FANTASTIC and can bump like weak subs. I want to put in Alpine SPS 600C components in the doors,and hook up a Profile 1040 amp to the four components. I am also going to install 2 10" bazooka subs, and run a Profile 1200 watt amp to them. The catch is that each amp comes with 2 free tweeters. So the RF's haves 2 tweeters each, the alpines have one each, and i will have four others. I would like to put these in the four corners of the windshield facing in, and the other two in the back somewhere. I want to know what else i need, what you think, etc. Dont bash on something you havent had a direct experience with PLEASE. PM or reply if you know your stuff or if you want to see the exact things im getting.
Ungrounded Moderator
You probably won't like the sound if you install all those tweeters - it will much too bright. Also, high frequencies are very directional so it's generally not a good idea to put tweeters behind you. One pair of tweeters in the A pillars should be plenty... keep the others for spares or sell them.
