Keylesss entry remote
Have each transmitter you intend to match ready for the
next steps. To match transmitters to your vehicle:
1. Turn the ignition to RUN, then to OFF. This
will disarm the Vehicle and Contennow ready to match the vehicle.
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your main instrument panel. When the fuse block is
open the radio fuse is located on the lower right hand
corner of your instrument panel.
3. Turn the ignition from OFF to RUN three times
quickly (within five seconds). The vehicle will
respond by locking the doors, unlocking the driver’s
doors and releasing the hatch. Your transmitter is
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
7. Check that all transmitters work by pressing
transmitters, replace the RADIO fuse.
not sure if any knows but I bought mine off of www.gmpartsdirect.com, I called the dealership and they wanted $85 for a new keyless entry remote and found mine on here for half the price.
