Rear left side speaker
Monsoon 500w system in 98 TA
Original speaker is 6.75" 2 ohm.
Found an Infinity 6.5" 2 ohm replacement.
Does anyone know the GM replacement #?
Ungrounded Moderator
...Sounds like somebody has a bit of an attitude (it's really too bad that nobody looked up a part number for you in all of eight hours).
Before you start replacing speakers I suggest you read the Monsoon FAQ sticky at the top of the forum. For one thing, the sail panel speakers (next to the rear seats) aren't 2-ohm - they're dual voice coil 4-ohm subs. The signal from the Monsoon amp is low pass filtered so installing Infinity 2-ohm full-range speakers there is definitely not a good idea.
