Burnt out fuse???
Old 03-30-2009, 02:23 PM
209ryder's Avatar
Default Burnt out fuse???
So i had no brake lights this weekend when i went to the good guys car show.And i went to a kragen to check the fuses and found two of the m blown???So my turn signals were not working either and i went to put the new fuse in and as soon as it touched to female end it popped so i grabbed another just to check did the same thing???Anyone know maybe what is grounding out and maybe where???I would like to find a wiring diagram so i could maybe find out the loop.
Old 03-30-2009, 03:36 PM
Z28LS1camaroguy's Avatar
yea definantly sounds like a wiring issue, have you done anything to the car lately??? you could have burnt up a wire or crossed one.
Old 03-31-2009, 10:57 AM
209ryder's Avatar
I dont think so. I have not done anything to it it came on all of a sudden
Old 03-31-2009, 02:03 PM
just pull the fuse panel and see if anything might have come loose possibly shitty connection, also check the grounds all through the car to make sure they are good.
Old 04-01-2009, 10:29 PM
209ryder's Avatar
hey thanks bro?? i will do it before the weekend dont have time right now will let you know the fix...
