Finished A4 to M6 swap
mine did the same thing but im still with the a4`s harness with minor upgrades.
u might need to wire the clutch pedal position switch
start by reading from here: https://ls1tech.com/forums/manual-tr...uested-25.html
I believe you need to wire the park/neutral switch from the auto shifter to the clutch pedal switch on the top, not the starter switch on the bottom...that way the cruise knows when you step on the clutch pedal and lets the throttle go before the engine winds up revving free...right now the cruise module is probably looking for that and seeing that it's in park/neutral, and not turning on in the first place.
I'd go nuts without the cruise, so if I can do anything to help I will...let me know if you need me to actually look at how the clutch pedal is wired in my car.
