Formula Radio Diagram
Always test your wires and don't go solely on a website. But, this one is usually pretty consistant. It only listed a firebird, but should be about the same.
http://www.the12volt.com/installbay/...tail/1862.html
thanks.. that helps but theres two yellows listed and same of the colors are pretty close i kinda need something like a diagram with the actual wires shown. any ideas where i could find something like that?
Did you check the Monsoon FAQ? I don't know if there are changes between 94 and 98 According to the FAQ the Monsoon headunit is no different than any other GM 1.5 DIN headunit. Maybe the wire colors and pin out are the same.
