Weird electrical problem
Every now and then when I have the key in the ignition in the axillary position, the inside lights will go on if i bump my steering wheel or move around in the car to make the car start moving. I'm assuming it has something to do with the shock sensor from the alarm because it only does this when there's some kind of movement or vibration in the car.
Have any of you experienced this before? Also what could I do to fix this?
It sounds like something is loose somewhere.... couldnt say exactly. It has nothing to do with your shock sensor tho.
