Sub volume fading in and out... - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 07-21-2009, 08:23 AM   #1
Default Sub volume fading in and out...
Just got done putting a 10" Alpine Type E sub in my 99 Z28 this weekend. Running it off of a Kicker amp which gets its signal from the MTX re-Q5 LOC. I set up the sub/amp volume to my likings and for the first day or so it was fine. Then last night the sub was hitting like I wanted it to, then all of a sudden the sub started hitting really freakin hard. Which isn't really a bad thing I guess, but its not consistant and has me baffled. I like my boom, I just want it to stay at where I set it up. Anyone have any ideas as to why it would fade in and out? Do I need to get a higher rated alternator? Bad connection?
Better put this info in here: Stock head unit and all other speakers still running through the Monsoon amp. The Re-Q5 is pulling the signal before the Monsoon amp. Its pulling the signal from the sail panel speakers.
Vogos97c5 is offline   Reply With Quote
Old 07-21-2009, 04:29 PM   #2
Speed-controlled volume?
dragonrage is offline   Reply With Quote
Old 07-21-2009, 05:27 PM   #3
pheer's Avatar
i don't think it'll help but, i had a volume problem in one of my older setups and it ended up being a loose ground wire...
it getting more power than normal.....maybe a short somewhere? though i would think it wouldnt work at all with a short, or it'd blow a fuse or something....
pheer is offline   Reply With Quote
Old 07-21-2009, 09:21 PM   #4
I have the SCV shut off because I find it really annoying. I'll have to start going through the connections and looking for something loose or not making good contact...Yay! ha ha.
Tags
10, 2002, fade, fades, fading, hard, hitting, monsoon, normal, pontiac, speaker, subs, subwoofer, subwoofers, trans, ws6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
