Replacing Tweeters in a stock monsoon camaro?????
Can I buy aftermarket tweeters and mount them in the a pillars near the windshield and still use the stock monsoon system? I would use the wiring from the door tweeters and run it to the a pillars if it would work. All the rest of the system is stock and I would like to keep it that way as I don't have money to "ditch the stock and get xxxxxx" etc.
It won't sound ideal, but you can do it. I'd cut the tweeters in the door speakers out of the circuit. I highly recommend Seas Neo tweeters. Both the silk and the metal versions are very good.
I have heard silk tweeters are better than metal? what should I look for in a tweeter as far as materials (construction) is concerned?
I've got some Rockford 6.5, with tweeters, that I pulled out of a wrecked TA. They look to be good quality. I'm wondering how they will sound. The stock ones are busted both sides, so it has to sound better. It looks like there is a filter on there. I hope it comes out ok.. Did you ever get around to doing it?
