Stereo turning off and on
Old 08-06-2009, 02:34 AM
uLs1a's Avatar
Default Stereo turning off and on
For the past couple of months my stereo has been acting up. I will be crusing around and out of nowhere my stereo will shut off and restart itself. After it restarts it will be fine for a few seconds and shut off and restart, it does it about two or three times and then it will be fine for awhile. I had a Clarion for awhile before it broke and had no problems with it, but about 2 years ago I bought the Alpine CDA-9886. The Alpine worked great but only until a few months ago when it would shut off and restart. Anyone have any ideas what it could be?
Old 08-06-2009, 07:33 AM
Ungrounded Moderator
WhiteBird00's Avatar
Do your power windows stop working at the same time the radio cuts out? If so, you probably have a problem with the RAP circuit in your BCM. There is a thread here on repairing the broken solder joints in the BCM to fix this problem.
Old 08-06-2009, 07:54 AM
SparkyJJO's Avatar
How to get the BCM out
https://ls1tech.com/forums/10217921-post47.html
And the solder points you need to reheat (the OP of the thread removed everything hence why I reposted the picture)
https://ls1tech.com/forums/11970245-post121.html
