How to solder wires?
I have the eurolights sealed beam conversion kit for my Trans Am and want to solder the wires instead of just electrical tape or something. My question is, can I just solder the wires together straight up? or do I need something in between them. Yes I am a total noob so go easy on me
Save the manuals!
Not if you want them to hold. Solder is not a weld or a structural connection, so you'll need a crimp connector to really hold things. (It just gives you better electrical contact across the wires. GM dealers apply special crimp clips that also takes solder.)
If you want to avoid buying special tools, you should probably go with a good structural crimp connector and use heat shrink tubing, tape, etc. to seal it from the elements.
Copy & Paste Moderator
I solder most connections and use heat shrink tubing to seal the connection (make sure you slip the tubing over the wire before soldering). It works well. My method is to interleave & twist the wires together (ex: -----===------) and solder that connection. There are some soldering guides around including on YouTube. The basic premise is to heat the connection and touch the solder to the hot connection. The solder will flow into the connection. Make sure you get good solder penetration and coverage. The completed connection should be a shiny silver. Be careful not to overheat the connection and cause damage to the part.
You can also solder crimp connections. Use connectors that don't have a plastic or rubber cover or cut the cover off. Slip heat shrink tubing over the wire (back down away from the connection for now). Crimp the connection like normal. Heat the connection with a soldering iron. Touch the solder to the connection and make sure to get good coverage and penetration where the wire inserts into the connection. Then slip the heat shrink tubing over the connection and use a lighter to shrink the tubing. Avoid touching the flame to the tubing. Depending on the tubing you have, it may melt instead of shrinking. There are different size shrink tubing and different size solder. Use the size tubing that fits the connection but is slightly larger so there is a little room to move.
I prefer thin rosin-core solder. You can find it at Radio Shack and other electrics parts places. Its easy to work with and you don't have to worry about flux. Don't breath the fumes though.
Get yourself some of the shrink tube that has a sealant inside. It's meant for wet locations. Much better seal than just plain shrink tube. Personally, I've never had good luck with rosin-core solder. Much easier with flux, and don't be shy with the flux. That's what sucks the solder into the wire. Make sure to tin your connections first. Makes it that much easier. I also have never had to worry about using a crimp connector on top of solder in the connection. If you run your wiring correctly with stress relief points you will not have any issues. Just my .02
I pretty much always use rosin-core solder. It works for me. I guess it comes down to personal preference and experience with the different materials.
My reference to crimp connections was more for terminals than butt connectors. I guess I should have clarified. If I'm soldering, I don't bother with butt connectors.
Gotcha on the connectors. I was kind of wondering.
