No turn signals....
No turn signals....
Well, I had some major clutch problems and took the car to a transmission shop. After getting the car back i noticed i didn't have any turn signals. checked the fuse and it was blown. I replaced it with the proper 20amp fuse, turn the ignition on and watched the fuse pop.
The transmission shop is, at best, a bunch of slightly educated monkeys. I will be getting the car back to them so they can figure it out, but if i can find the problem myself it would really help things out. All they did was put a new clutch in the car, i'm really lost of what the hell they could have done. any help would be appreciated.
figured it out. Th transmission shop had put the plug that goes into the reverse lockout solenoid, into the CAGS solenoid. I fixed that but didn't try to put another fuse in, and thats all that was needed. I forgot the turn signal/ reverse light is on the same circuit.
