Where to mount amp....stealth...
Old 03-31-2010, 07:28 AM
pitbull14218's Avatar
Thumbs up Where to mount amp....stealth...
Hello, i just purchased a stealth enclosed 10" sub and amp for it, where do people usually mount the amp? I don't want it visable and I don't want to really drill holes that i will regret. I was thinking in the spare tire area... any ideas?
Old 03-31-2010, 07:39 AM
DAVE00's Avatar
Mounted my 4 ch exactly there. Just mocked up a piece of wood and bolted it to the spare tire mount and then screwed the amp to it. Can't see with the trim panel back in and worked out great. Unless you will need your spare sometime it's a great place for an amp.
Old 03-31-2010, 07:50 AM
Thats what i was thinking of doing, mounting it to wood and mounting the wood to the spare tire attachment thingy.
Old 04-01-2010, 01:13 PM
BUMP, i'm going to start this today, any other ideas, any pics of peoples setups similar to what i am trying to do, thanks
Old 04-01-2010, 02:38 PM
99Bluz28's Avatar
If you not using the factory Monsoon Amp, then remove the amplifier from the factory mounting bracket. Then with some light modification you can mount your NEW subwoofer Amp to it.
Old 04-01-2010, 02:44 PM
2000pontiacws6's Avatar
Default spare tire
would the spare tire even be useful on a lowered T/A?
Old 04-01-2010, 04:03 PM
Chrisd000111's Avatar
heres a pic of mine i wanted something kinda stealth but can still show it off plus i dont think a 5 channel will fit in the spare area( while still keeping the spare)
Old 04-01-2010, 10:40 PM
BandDirector Blk98ZM6's Avatar
Check out the link in my sig...I've got a 4 channel amp mounted in my spare tire and another one mounted behind it. I still have access to my spare if I need it in an emergency. I've got directions on how to do this on my site too...
Old 04-02-2010, 07:46 AM
Im keeping my monsoon amp, Just probly going to mount the amp on some wood and bolt it down hidden, do you think the amp could overheat in that area?
Old 04-02-2010, 12:31 PM
99Bluz28's Avatar
You can mount it under the front passenger side seat if the Amp isn't very big.
Old 04-04-2010, 01:40 PM
cookba's Avatar
Old 04-04-2010, 03:40 PM
white3800camaro's Avatar
I have mine in plane sight, but, I know many people will put it in the spare tire area, or even by a amp rack, they look nice, I would get one if it would fit with my box
Old 04-04-2010, 04:06 PM
Empatho's Avatar
I have mine in the spare tire area just chilling there with some stuff to keep it from bouncing around. And by stuff I mean a few rags I need to get some longer speaker wire and a board, so I can do a legit mount.
Old 04-05-2010, 09:59 AM
Mounted, sounds AMAZING!!!! JL 10w3, im only running around 150rms to it from my Kicker Zx300.1 but sounds so good crisp and clean!!!! I'll have to post a pic of how its set up later.
Old 04-05-2010, 12:11 PM
ska4life07's Avatar
I have mine chillin on top of the main trunk area behind the seat. I have to since the box takes up all the space in the back.
Old 04-05-2010, 12:31 PM
RsSean's Avatar
Mine is set up using all the factory nut and bolts in the spare tire rear. There two from the bumper cover with the black nuts with washers, and then the amp is slid behind the power antenna and bolted to the bracket off the power antenna. No hole were drill in the car.
Old 04-06-2010, 12:13 AM
bad_408_vert's Avatar
hmm Can a Mono amp be mounted in the spare wheel area and still keep the spare tire?
Does anyone have the specs of the dimensions of the monsoon amp?
Old 04-06-2010, 11:34 AM
99Bluz28's Avatar
Monsoon amp: 7.5" wide x 8" deep x 2" tall .
By mounting a piece of 3/8"to 1/2" thick oak plywood to the monsoon amp plastic mount, you can mount up to a 8" x 15" wide Amp in the factory location.
The Amp should be under 2.4" tall also.
Old 04-06-2010, 12:15 PM
Thanks 99!
Old 04-06-2010, 01:59 PM
thecobrahunter's Avatar
Did what Dave00 did from one of my sub amps.
Amp is right behind the sub box.
Quick Reply: Where to mount amp....stealth...
