Best Place To Mount Shift Light
I need to know where the best place to mount a shift light is for a car with an interior I want to keep stock looking, I don't want one mounted on the dash and would prefer not to mount one on in the speedo/gauge cluster area, just wondering if there is anywhere safe to install one that is kinda hidden outta sight outta mind type of thing that still is visible when driving.
Any ideas?
Thanks for the input in advance,
Jeff
Any ideas?
Jeff
Any ideas?
Jeff
Any ideas?
Jeff
The other popular place is behind one of the AC vents. If you search, you can probably find a ton of pictures in either of the two places I mentioned to see what works best for you.
Also what do you all think about the Auto Meter digital pro shift system, I had the digital tube shift light in my Cobra and liked it but for the Camaro I would probably opt for the digital shift light gauge/tach and mount it in an A pillar quad or tri pod, I know its a bit more expensive but I kinda wanna see RPMs as well, since I got my h/c/i done I have noticed I have a pretty lazy factory tach, the limiter is set to 7200rpm and its smacking the rev limiter at a reading of 6500 on the factory tach....so this would be a good option..
i just installed mine on the steering column. its mounted right in the middle of the rpms so nothing gets blocked. I can see everything perfect and nice bright light even during the day. But if you are wanting a stealth look then either in the center ac vents, a pillar vent or down below the radio somewhere.
Re: Best Place To Mount Shift Light
Any ideas?
Jeff
Any ideas?
Jeff
