Amplifier interfearing with horn/fog relays?
98 Camaro SS. I have the power cable for my JBL amp hooked into the power source on the relay/fuse box under the hood, that contains the horn and fog light relays. If I dont run the vehicle for a day or more, the fog lamps and horn wont work, until I run the vehicle for at least a half hour/20+ miles. I have replaced the relays before, and solved the problem for a while. Could have my amp power wire hooked up there be causing this? Or should I get a new relay box? Anything else to check?
but ive also ran the wires from the driver side from where the fuse box gets power
and i have 2 amps.. (500w and a 700w)
It's just a 760 watt JBL amp. I didn't hook it up there, a professional installer did. I guess that it sounds like the best course of action is too hook it to the battery, and see what that does.
