Keyless Entry Question
Old 07-07-2010, 10:58 PM
nastyiroc's Avatar
Default Keyless Entry Question
I just bought a 1998 camaro z/28 and it did not come with a keyless entry remote. And I looked on the door and it did not have the keyless option. My question are all ls1 cars equiped with keyless entry because it has the red light on the dash board.
Old 07-07-2010, 11:14 PM
tdevil55's Avatar
The red light is the security light, I belive all the 98+ had them. It deals with the VATs system, where if the ignition is turned on without haveing the proper signal from the resister in the key, then it will kill the fuel pump after start and then the car cant go, GMs way of keeping the car from easly being jacked. I think the remote entry is seperate from that.
Old 07-08-2010, 12:27 AM
nastyiroc's Avatar
So can I try and program a remote.
Old 07-08-2010, 07:29 AM
Ungrounded Moderator
WhiteBird00's Avatar
No, the red LED on the dash next to the defroster vent is for the optional alarm system. The VATS indicator is the SECURITY light in the instrument cluster.
The alarm system was not available without also having keyless entry. The RPO code on the door sticker for keyless entry is AU0 and for the alarm system it is UA6.
You can test for the options you have by following these steps:
PROGRAMMING THE FACTORY ALRAM
ENTERING PROGRAMMING MODE
To program features, the car must be in programming mode.
1) Turn key to RUN position.
2) Turn key to OFF position.
3) Remove the RADIO fuse in the main fuse panel.
4) Turn the key to ACC
You should hear a chime to verify that the system is in the programming mode.
1 chime means you can program Exit Lighting, Delayed Illumination, Last Door Closed Locking and Lock Out.
2 chimes means your car is equipped with Content Theft-Deterrent System so you can also program Remote Keyless Entry Verification, Arming Method, Arming Verification, Driver's Door Delay and Shock Sensor Enable.
LEAVING PROGRAM MODE
When programming is done, turn the ignition to OFF and replace the RADIO fuse.
If you get two chimes, that will confirm that you have the factory alarm.
Old 07-08-2010, 09:26 AM
tdevil55's Avatar
^^^ there ya go. Learn something new everyday.
Old 07-11-2010, 08:20 PM
nastyiroc's Avatar
I tried programming a remote from a 97 boneville but it won't work. Any thoughts or do I just need a newer remote?
Old 07-12-2010, 11:03 PM
Crispy's Avatar
I believe that has the old style remote. In any case you will need GM P/N 16245100 or something listed as compatible to that. You may find more than one since they updated remotes as years went on.
Old 07-13-2010, 09:06 AM
killagt's Avatar
what RPO code I need to find out that my car have keyless entry option ?
Old 07-13-2010, 09:26 AM
Already listed in post #4...
Old 07-13-2010, 01:20 PM
killagt's Avatar
Old 07-18-2010, 02:08 PM
nastyiroc's Avatar
got a remote from a 2000 z worked great thanks for all the help
Old 11-10-2018, 07:13 PM
Justin Lithgow's Avatar
Originally Posted by killagt
I also have a 2000 chevy camaro v6 I got with out a key fob I have the red blinking light on the dash an I checked the door an under service part identification there is the two sets of letters you mentioned but I don't know how to read them can you help me I need to know which key fob I should order thanks
Old 11-12-2018, 07:22 AM
The GM part number is 16245100. Most for sale listings will include that number (or the stamping number on the case 16245100-29). However, some will actually show the wrong fob for that part number - the one you want is the 4-button model (lock, unlock, hatch, and panic button). Amazon has them for $11 and up, other sites may have varying prices.
Quick Reply: Keyless Entry Question
