Trunk wont pop
Old 07-22-2010, 09:49 PM
cbailey's Avatar
Default Trunk wont pop
After having a blown fuse for my courtesy lights go, I removed and replaced that guy then later that night I noticed my trunk wont pop with the button or the key fob. I can hear the button make noise when its pressed also when I press the button on the key fob. Trunk just wont open electrically???????
Old 07-23-2010, 10:33 AM
Save the manuals!
wssix99's Avatar
What happens if you pull up on the hatch while you pop it? Your latch spring or struts or both could be shot.
Old 07-23-2010, 10:57 AM
cbailey's Avatar
No it wont electrically pop, it opens fine with the key.
Old 07-23-2010, 11:21 AM
PwrHngryLT1's Avatar
try this:
http://www.installuniversity.com/ins...elease_fix.htm
or
http://www.installuniversity.com/ins...ease_fix_2.htm
Make sure your connections on are intact on the hatch realease machanism.
Old 07-23-2010, 12:31 PM
Ungrounded Moderator
WhiteBird00's Avatar
Check your PWR ACCY fuse. The COURTESY fuse protects the coil side of the hatch release relay through the BCM but it's the PWR ACCY fuse that actually powers the release mechanism.
Quick Reply: Trunk wont pop
