Quick electrical question
I'm curious where I can tap into the fuse panel to power my electric cutout? I've heard of people tapping into the cig lighter for the power, but I use it for my radar detector and phone charger.
"mini fuse add a circuit"
You add these to your existing fuse box and is a lot more safe for your electrical system than tapping into existing power wires.
Ungrounded Moderator
There are existing ports in the fuse panel designated by GM for adding accessories. They are single-sided ports (like half a fuse port) labeled BATT (battery constant power), IGN (ignition switched power), and ACCY (retained accessory power like the radio and windows). Each is a 15 amp circuit.
