Only one speaker works????
Hey guys, I have a 1998 Z28 that I took to the race shop to be built. I brought it with my speakers and radio working. When I got it back from the shop only the passenger side speaker works the one all the way in the hatch. So I only have one speaker now. I thought maybe the speakers just blew out because of age, but then as the car is driven more and more and we realize how I just got bent over and everything was done shady and spotty. So now I think they pinched a wire or something. They broke the plastic kick panel on the passenger side, the one that you have to take off to get to a plug up under the dash to drop the motor. Is there any speaker wires under there that they could have fucked up in the panel?
chris
chris
There is a harness under the kick panel and up a bit, that is where the harness is that goes through there, into the rubber grommet that goes through into the door itself. The kick panel is easily removed and you can have a look in there and see if anything is damaged. Good luck!!
