**Interior Lights and Locks do not work.**
Well i have a set of LED's in my interior.... and the light that covers the rear seats and some of the hatch area started to not work properly.
So i decide to remove it.
I take a small trip to my uncles....
and i noticed my interior lights are all out! (even my glove compartment one)
And my doors wont lock....
i need to lock them manually but the switched on both doors wont work
One thing i did notice was when i try to lock or unlock the car with the
switches on the doors
I can hear like a relay or something clicking on the passenger side under the glove compartment.
Also when i drive the car around i can hear this relay or ticking sound go on time after time when I'm driving.... ( guessing it trying to lock the doors since I'm driving and the doors are still open.
And yes i checked all fuses inside the car and in the engine bay
there all clean.
And another note my gauges still work.... and light up at night time
Any one have any ideas?
Hopefully whitebird or some one else can chime in on this one.....
there all clean.
Ungrounded Moderator
Replace your COURTESY fuse. It protects not only the courtesy lights but also the BCM circuits that control things like power locks.
Never rely on a visual inspection of fuses - they can be blown but still look fine. Always use a tester or replace with a known good fuse.
I did use a tester and it did say it had a connection...
must be a shitty *** tester
But i found the light that is on top of the rear seats completely toasted...
the locks work now....
but the lights still dont come on =/
i removed the top cover of the car the wire running to the light is completely burned.....
no power what o ever.
do you guys think i burned out my BCM?
Possible but doubtful. Your locks, hatch release, radio, power windows, alarm, keyless entry, audible chimes and VATS are all controlled by the BCM along with the courtesy lights. If the rest are working it's unlikely that the BCM is damaged although it is possible that just the courtesy light circuit was damaged.
The courtesy lights are a closed circuit where both power and ground go to the BCM (the lights don't ground to the chassis). The damaged wires could be keeping the circuit open (incomplete).
Basically, the courtesy lights are controlled by the BCM. Power is provided through the blue wire and ground through the white wire. The BCM provides constant power except after the battery saver function is activated (about 15 minutes after the ignition is turned off). It controls the courtesy lights with the ground - it reduces ground gradually to provide the theater dimming effect.
I'm traveling so I don't have schematics with me but I'm sure they've been posted before - a search should find them.
Thanks again. I will look for schematics again. My small led flashlight is now getting real annoying.
The courtesy lights are wired in parallel so they're not like a Christmas tree - if one light burns out, the others will still work.
Here is the schematic:
It is probably not necessary to trace individual wires. Chances are that the problem is with the BCM rather than a broken wire (assuming the COURTESY fuse is okay). Check for power coming out of the BCM on the dark blue with white wire. Also check for ground on the white wire at the BCM. If you don't get them then the problem isn't with the wiring.
I would guess that the problem will be on the power side. Otherwise the map lights would still work since they have an independent chassis ground.
Reviving this old thread as I am having this exact problem in my 2002 Trans Am: Whitebird hoping you can help. Thanks for the schematic above, I saved it. I am having the exact same issues described in this thread.
Editing the post as the original was just too long. If you have questions or want more details let me know. Basically I have installed new LEDs in the rearview mirror and the ashtray. I have no bulb of any kind installed in the rear map light. This is because it stopped working a long time ago and I just hadn't gotten around to troubleshooting it. The bulb is good, I tested it on a 9V battery and I get 7V when I put a multimeter on the terminals so I am not sure at this point what's wrong.
I did some troubleshooting on it this weekend trying to get the original 212-2 filament bulb working. First time I tried to install it the Courtesy fuse blew and I replaced it. Doing more testing I noticed any time the bulb was connected the LEDs in the Rearview mirror went extremely dim, even though the bulb itself did not light up. Also anytime I had this bulb connected, trying to turn on the courtesy lights in any way, I heard an the audible click in the dash mentioned above. Left alone the click repeated every 30-45 seconds or so. I ultimately stopped troubleshooting and left the bulb out so nothing is in the rear map light now.
The real problem is that now (with the new LEDs installed in the Rearview and ashtray) I found out today that my door locks don't work at all. They worked fine before with one exception. The door lock switch in the driver's door won't unlock the passenger side door. I can unlock it with the remote so I had assumed something was bad in the switch in the door or the wiring in one of the doors had a problem etc... Between the weird things happening trying to re-install/troubleshoot the filament bulb in the rear map light and what I read above it seems like installing the LEDs have caused some problems. I'm going to install all the original OEM bulbs back tonight and see what happens.
Any ideas or help would be appreciated. Doubt its a power issue out of the BCM as mentioned above because the LEDs all light up fine.
Well I figured it out. Just basically pulled all the interior LEDs. Pulled the Courtesy fuse out. Added all the LEDs back in one section at a time, each time adding the fuse back in after the LEDs were installed. Did this 3 times till all lighting was re-installed. Everything works perfect now other than the Door Lock switches seem to be hit or miss if they work. I think there is another thread on that so I am off to read up on that.
Bottom line: Installing LEDs anywhere in the interior without completely removing power first seems to cause very weird problems. Most will likely tell you to disconnect the batter ANY time your messing with electronics but this just isn't something I normally do for a simple bulb swap.
Can't let this thread die yet.
I have a 98 SS with OPs, almost, same issues. Since I bought the car the locks/dome lights haven't worked and when I hit the locks it just either dings or clicks under passenger air bag area.
I read this page and then went out and checked my courtesy fuse and it was in fact blown. I put another 20a fuse in and then my interior lights turned on and my door locks worked, all for about 15 seconds. After I locked/unlocked my doors by the door switch a couple times, I tried with my key fob and it locked, then the fuse blew again. I tried a couple of things while replacing the fuse. I had the door open for a couple of mins then replaced it and nothing happened until I turned the car ignition on, then all the interior lights came on but dimmed and then I tried the lock and they did not work and the manual dome light switches went back to doing nothing.
I have no idea what my next steps are, do I follow the wires from the door locks to find a short? I have never dove into any electrical issues so any tips would be greatly appreciated!
Thanks
Thanks
You need to determine whether the problem is with the locks or the lights. Both run off the COURTESY fuse through the BCM. To tell which is causing the problem, try operating one alone and see if the fuse blows. For example, put in a new fuse and keep opening and closing the door to turn on the courtesy lights without using the locks. Keep doing that until the fuse blows or for enough times to be sure they are not the problem. If the fuse doesn't blow then try repeatedly operating the door locks to see if that causes the fuse to blow.
Once you've reduced the issue to one circuit or the other, you can start looking for electrical issues in that circuit. It sounds like there isn't a dead short because the fuse does not blow immediately so it would seem to be something that is drawing too much current causing the fuse to blow eventually.
Thanks for the reply!
First, I unhooked the trunk light because I saw some people saying it caused issues, when I took it apart all the components look as if they were brand new, but I left it unplugged. I put a new fuse in and opened the door and the interior lights came on. I opened and closed the door and had the light stay on for about 10 mins. Then I unlocked/locked the doors with the door switch and that worked, then with the key fob in which that worked.
I am unsure what my issue was before (Possibly the trunk light but don't really want to test as I really wouldn't use it) but as of right now everything is working as hoped. My only guess is either the, probably 4, fuses I previously put in were bad, or the actual fuse socket didn't have a good enough connection because the bracket didn't really seem to hold the panel into place.
Thank you!
Thank you!
