NEW PRODUCT: Heads Up Display!!!
Copied from my site...
So, do you feel left behind now that GM is offering Heads Up Display on the new Corvetttes, Camaros, etc? Have you tried to retrofit one of their units only to find out it would cost well over $2000 in parts and labor? Well, we have the answer... Heads Up Display for OBD II Vehicles!!!
Plug and Play for any 1996 and up Vehicles. install in 10 minutes or less.
No Professional Installation Required HUD System.
Project Speed ( Mph or Km Only not both ) Please choose at Available Options.
Rpm, Water temp, Volt on to your windshields.
Speed warning function which can be set up by user.
Rpm warning function which can be set up by user (shift light).
Water temp , volt warning function which can be set up by user ( water temp gauge & volt gauge).
Head Light switch on warning function ( when dark).
Auto dim when dark.
May required water temp adapter.
Professional Installation may be Required.
HERE IT IS ACTUALLY INSTALLED IN A FOURTH GENERATION F-BODY....
$180 and SHIPPING WITH THE 48 STATES IS INCLUDED!!!!
Check it out here...
http://6litereaterdesigns.com/store/...roducts_id=244
Auto dim when dark.
By looking at the pictures it looks like you mount it where ever you desire on the front of the dash. I'm just guessing since the first pic shows it higher up on the window where the rest of the pics show it in the bottom left (which looks better IMO).
Mount it wherever you desire. If your speedo is off this will NOT be off as it is based off the computer. I think I can get OBD1 HUDs as well...
Took a video, will post in a bit...
Price changed, $180 shipped. My first calculation was $20 high because I didn't realize I was including almost 10% sales tax from Cali...
IMO if its off because you put a gear in then this will be off as well, if its off because your gauge is screwed up then this will read right. I bet it gets its signal from OBDII port so its gonna be same as dash
