Integra amp remote wire
A friend is trying to figure out wher to hook the remote wire from the amp to. It is a 95 integra. Looks like you hook it up to the power antenna wire. Or do you hook it up to the 12 volt ignition wire? Shot in the dark I know, but just trying to help a friend out. Thanks
You hook up the remote wire to the remote wire on the head unit. Should be a blue/white wire on the back and most head units even have it labeled. Unless you're talking about a stock radio and in that case you could just hook it up to any ACC that turns on when you turn the key.
