Ground Wires
Ground Wires
I think I have a bad ground connection because it sounds like I have electrical interference coming through the radio from my plug wires.
Under acceleration I start to hear a strange noise that sounds like a spark or a short and it sounds like it is coming through the head unit. It happens when the radio is off though as well.
I am really puzzled on this sound but I think this may be the solution. Where are the ground wires located and is there a way to test to interference?
Save the manuals!
Have you changed anything with the electronics or stereo? Has this been going on for a while? If not, then you alternator may be about to die?
Here's a good article on alternator whine (I expect this is what you are hearing) with probable causes: http://www.crutchfield.com/S-X9jsogt...ech/kb348.html
Its not so much a whine its a nails on chalk board sound only not as intense as that and its not a constant noise its for a brief second over and over and the speed of it depends on the acceleration.
If it happens when the radio is off, are you sure it's even coming through speakers? could be a bad pulley. Cold weather tends to make worn pulleys much more noisy, and their sound can be intermittant vs constant etc.
Rpms of the engine and only while accelerating past 3500 or so. Its not the speakers the sound is from the front of the car and its not a bearing in the trans because I just had that rebuilt and its still making the noise
no its only under load. I was thinking it could possible be a bent valve maybe or a spring. Its a h/c car but their is no ping or knock, it accelerates smooth so I eliminated that option.
