help help!!! window wont go up!!!
ok so put a new motor in just 2 weeks ago and im in the middle of a trip to texas and my window wont go up!!! is there a way to get it up bypass orr sumthing? direct power.......
Lift up on the window as you push the window up button to get it to return up for this time. As a permanent fix, check the wires as well as the internal fuse mechanism inside the motor. If you have horrible luck, you might have burned it out - but you may figure out how to ghetto rig it for a quick fix
I was stuck in the same situation for a while. My window motor just gave out or something while the window was all the way down and I could not get it up. REALLY sucked as this was in like December...cold as ****.
The temporary fix? Bang on the door while you hold up the window switch. Specifically in the door handle area (not like the lever but the support that you use to pull the door closed). My friend told me to try it and my jaw dropped as I watched the window rise up. I didn't take any chances though, I left it up until I got a new motor lol.
Save the manuals!
One of two things most likely happened:
- You got a rebuilt motor, which included a bad/old thermal cutoff switch. (This is the part of the motor that is failing on you. BTW - Its going to get worse very quickly until the motor won't work at all.)
- You got a box with someone's old motor in it. People will buy a new motor and then take their old one back, saying they didn't need it, etc. and get their money back. (Sometimes its hard to tell if a motor is used or not.)
I've had both of the above happen to me.
If you take your motor back to Autozone and get a refund, make sure you get a Dorman design from them as a replacement. They are 100% new motors and are better sealed than the old design. Guaranteed you'll be happy after you do that.
