Problem with Bazooka sail panel speaker
Old 04-02-2011, 11:35 PM
RedStreak's Avatar
Default Problem with Bazooka sail panel speaker
I have a complete 2001 Pontiac Monsoon system. I contacted SparksAI and ordered a set of the DVC Bazooka's for each sail panel and installed them yesterday.
I clipped the factory harnesses off the old speakers. I then soldered the harness onto the new ones, reconnected the harnesses, drilled new holes with self tapping screws and was all set. The passenger side worked fine at first, then it started vibrating and not producing any bass almost like it blew. It did this for a short period of time, then started working properly again suddenly. I'm having the problem now again, so it appears to be intermittent. The driver side has been fine the entire time. What could be the cause?
Old 04-03-2011, 08:31 AM
Save the manuals!
wssix99's Avatar
Check the wires and your soldering job. You may also switch the two speakers and see if the issue is with the speakers or something else in the system.
Old 04-03-2011, 04:08 PM
RedStreak's Avatar
Swapped the other harness over to the troublesome speaker and the problem persist. I also tried swapping the speaker to the other side and the problem persist. It is a blown or defective speaker. Well, I'll start the warranty process and contact SparkAI for guidance. Hopefully I just got a lemon and Bazooka speakers are reliable.
Old 04-03-2011, 09:10 PM
KEE AUDIO's Avatar
Bazooka 6.5" subs have always been bullet proof. I have only had about 2 come back out of several hundred.
