Deleting the factory bose stuff?
Old 05-07-2011, 10:29 AM
camar0corey's Avatar
Default Deleting the factory bose stuff?
I have a 94 Z28, it has just three speakers(Bose). Do the door speakers have amps also? I was thinking of deleting all the factory speakers and just running something in the sail panels. Will it sound alright? If I go this route what should I put in the sail panel, 6x8, 6x9?
Head unit is a Alpine CDE-102. Would I just pull all the factory speaker wiring and run speaker wire to the sail panels? How would they mount in the sail panels, are there already holes for screws?
Old 05-07-2011, 09:02 PM
94T/A5.7LT1's Avatar
What's the purpose for deleting the speakers in the doors and just running some in the sail panels? Are you trig to lighten the car? I honestly don't think it would sound right, I'm also not sure a 6x9 won't fit in the sail panel either.
Old 05-07-2011, 10:59 PM
Trying to shed some weight, I thought I had head the front speakers had amps too so I figure they have to weigh something. I suppose I could just run two door speakers? Would that sound better than running speakers in the sail panels?
Old 05-07-2011, 11:07 PM
pentavolvo's Avatar
would deffinetly sound better then running rears only.. just get some 16ga speaker wire and cheap 6.5 coaxs
Old 05-07-2011, 11:26 PM
^agree with penta, a whole lot better. Im not sure on the camaros but my 94 TA door speakers did not run off the amp. The amp only powered the subs in the sail panel.
Old 05-08-2011, 07:37 AM
Ungrounded Moderator
WhiteBird00's Avatar
Bose systems had individual amps on each of the speakers. They also used a common ground system so you will have to run new wires when replacing speakers.
Old 05-08-2011, 08:51 AM
Thanks everyone, I'll just run some door speakers then. I was planning on new wires anyway, its such a mess behind the head unit. There is this black box I guess to make the head unit happy with the Bose stuff, there is just wiring everywhere.
What would be a good pair of door speakers, knowing this is all I will be running?
Old 05-08-2011, 10:11 AM
pentavolvo's Avatar
some cheap pioneers from walmart prly work fine
Old 05-08-2011, 10:26 AM
cfallsguy's Avatar
That black box is probably the DRL module. Get a good pair of speakers so you don't have to replace them all the time from getting blown.
I tried those awhile back just temporarily and they sucked, within no time they were blown which sounded worse than stock.
Old 05-08-2011, 07:25 PM
BCKNBLK's Avatar
yep,, i get all my speakers on ebay.
Old 05-09-2011, 07:13 AM
The black box is probably an adapter for the Bose system such as a PAC OEM-1. It is basically an adjustable line out converter that steps down the speaker-level output of the head unit to the low-level input needed by the Bose amplifiers. I don't think the 94 Camaro had DRLs so it wouldn't be a DRL module.
Old 05-09-2011, 12:27 PM
So if I were to just run two door speakers, what sounds good?
Yeah the little black box is by Scosche or something like that. I just see it as a huge mess that could disappear.
Old 05-09-2011, 01:06 PM
cfallsguy's Avatar
Oh alright. Anyone know the differences between the Bose adapter and DRL module, such as size and location? Not familiar with the Bose setup.
Old 05-14-2011, 09:33 AM
Should I go with Alpine type R's or something? Speaker recommendation, just to run two door speakers.
Pulled the rear Bose yesterday, if anyone is looking for one. Damn that was a clunky funky shaped box.
Are the Pioneers really that cheap that with just 50w I'll kill them?
Old 05-14-2011, 10:43 AM
Spartan7's Avatar
94 cars don't have DRL's. That started in 97. I was personally very happy with my old 5 speaker Bose setup, but to each their own.
Old 05-14-2011, 01:20 PM
pentavolvo's Avatar
no matter what you put in that headunit only has 18watts rms so as long as the spekaers can handle 18watts rms you are good
Quick Reply: Deleting the factory bose stuff?
