Turn signal problems help!!!
Old 06-25-2011, 01:41 PM
nikeboy313's Avatar
Default Turn signal problems help!!!
When I turn my turn signals on the lights don’t blink, they come on and just stay solid. But, if I turn my hazards on they blink no problem. What’s the issue?
Old 06-25-2011, 07:51 PM
01 Red WS6's Avatar
Did you make sure you don't have a bulb out? I think a tail light bulb will cause the same reaction as the front. Could be welding since it's been a long time since I had a bulb go out
Old 06-25-2011, 09:03 PM
colinpd137's Avatar
Your flasher is out, very easy/cheap fix. Its located up under the dash/steering wheel area. Just go to autozone and buy one, like 15$. Ill get a link for you here in a minute.
Old 06-25-2011, 09:04 PM
colinpd137's Avatar
http://www.autozone.com/autozone/par...69839_0_11714_
There yah go
Old 06-26-2011, 12:18 PM
mrrman's Avatar
Originally Posted by colinpd137
Does this link work? It times out for me..okay it now works
Old 06-26-2011, 05:35 PM
Ungrounded Moderator
WhiteBird00's Avatar
Check your bulbs first. Turn on the hazard flashers and walk around the car making sure all bulbs flash as they should. The fronts are most prone to failure but the tail light bulbs can go as well. Don't just throw parts like flashers at the problem until you've done some checking. If one side works but the other doesn't, it's not the flasher. If neither side works it might be the flasher but check the bulbs first.
You can get a universal thermal 2-prong flasher from any parts store and even Wal-Mart for more like $5 or less. Electronic flashers cost around $15 but they flash the same speed even if a bulb burns out so you lose any indication of bulb problems.
Old 09-25-2011, 07:06 PM
nikeboy313's Avatar
Hazards all blink correctly, no burnt out bulbs. Replaced the flasher and they still just stay solid.
Old 09-30-2011, 09:04 PM
nikeboy313's Avatar
bump ANYBODY?
Old 10-03-2011, 07:26 AM
Are you sure you replaced the right flasher? There are two of them - one for turn signals and one for hazard lights. The turn signal flasher is on the right side of the steering column, the hazard flasher is farther down on the left.
Old 10-03-2011, 07:34 AM
xX-Z28-Xx's Avatar
Sorry for the hijack, but would a flasher solve my problem?
https://ls1tech.com/forums/general-m...-properly.html
Old 10-03-2011, 07:55 AM
Posted some suggestions in the other thread.
Old 10-03-2011, 03:07 PM
nikeboy313's Avatar
I changed out the wrong flasher then. I'll swap out the right one and see if that solves it.
Old 10-03-2011, 09:19 PM
xX-Z28-Xx's Avatar
Thanks for that, I'll go at it tomorrow.
Old 10-07-2011, 12:57 AM
nikeboy313's Avatar
Tore the dash back apart and I can only find one flasher (the one on the left.) Any more suggestions?
Old 10-07-2011, 02:31 AM
Grim Crow's Avatar
autozone part number EL12 is an electronic flasher. had similar problem, switched to electronic flasher. If you ever change out the type of bulb or similar mod you'll probably need an eflasher anyway. there are two flashers under your dash, one for the hazards and one for the individual signals. when you take off the two bottom dash panels, look to the right (facing forward) and you'll see a little clip, on the other side of that clip/metal piece you'll find the flasher. basically directly opposite of the flasher on the left which is for the hazards
Old 10-07-2011, 03:58 AM
nikeboy313's Avatar
Yea i pulled it all off and looked I can clearly see the flasher on the left. Do you mean the other one for the signals is on the passenger side under the dash? I swear I looked forever and couldn’t find another flasher on the driver side. Could it be different for a ltx car than a lsx car?
Old 10-07-2011, 07:06 AM
No, according to the schematics there are separate flashers in 93-97 models just like in the 98-02 models. Unfortunately, I don't have a location diagram or photo for the earlier models but here is where you find it on later models (item 1 in the diagram):
The diagram is looking at the back side of the dash under the instrument panel. Remove the knee panel under the steering column and you will find the flasher clipped to the back of the dash panel just to the right inside the opening (above the OBDII port).
Old 12-10-2011, 11:51 PM
nikeboy313's Avatar
Long delay... But flasher has been replaced. Found one of my taillight sockets needed replaced. Did that. Still didn’t fix the problem. All bulbs are functioning correctly. Hazards flash but turn signals still solid. My next attempt is to replace the entire turn signal lever on the steering column. This is the last thing I can possibly think of.
Old 12-12-2011, 10:47 PM
WILDMN's Avatar
You may have a grounded wire. My last T/A did that. All of the bulbs would flash with the hazards but the right side would not blink. I have no idea how that worked but it did. I ended up checking the bulbs with them flashing and got shocked... That's how I found it.
Old 12-12-2011, 10:49 PM
xX-Z28-Xx's Avatar
, not as bad as peeing on an electric fence... never ever do that.... it doesn't feel good, at ALL
Quick Reply: Turn signal problems help!!!
