Metra Axxess ASWC Problem - No LEDs?
Old 07-02-2011, 12:28 AM
TheHeadFL's Avatar
Default Metra Axxess ASWC Problem - No LEDs?
So I am trying to wire up this thing... and it seems pretty easy, but I am getting no LEDs at all...
I've checked the following:
- Multimeter to the ASWC harness red/black pins shows +12V when ignition is on.
- Multimeter diode test on the ASWC board itself shows that the LED itself works
- ASWC wired to proper pin 14 in factory harness (although I think even without this I should still get an LED??)
Basically I am pretty sure the unit is just dead. Anyone have any ideas?
Old 07-02-2011, 01:16 PM
sjsingle1's Avatar
power.....but not working.....dead.......grounded good?
Old 07-02-2011, 09:38 PM
TheHeadFL's Avatar
ground is fine... it is grounded to the same ground as the head unit itself, which works fine.
and like i said, tested +12V on the harness for the unit itself, that was red/ignition/acc to black/ground in the harness.
Old 07-06-2011, 08:12 PM
TheHeadFL's Avatar
Update: Got my new ASWC from Amazon today, this one worked fine first try.
Was just a dead unit.
Old 07-06-2011, 08:40 PM
sjsingle1's Avatar
good news.....i thought it was dead too
Old 04-23-2012, 09:14 AM
lionel_luthor's Avatar
Can anyone help me with what wire(s) to tap into with the metra axxess? I just bought one & it should arrive tomorrow. It's for a 2001 WS6
Old 04-23-2012, 10:11 PM
TheHeadFL's Avatar
You basically need switched power, ground, and Pin 14 from the radio harness. I think its dark blue.
The power and ground you can get from really anywhere. Look up the harness diagram to identify pin 14.
Old 05-08-2012, 07:25 PM
nastyiroc's Avatar
You only need to tap into one wire of the factory harness?
Old 05-08-2012, 09:32 PM
TheHeadFL's Avatar
Thats right. And power and ground of course.
Quick Reply: Metra Axxess ASWC Problem - No LEDs?
