OCAR Radio Now at Double D Mods! Awesome Iphone upgrade option!
Closed ex-Sponsor Account
OXYGEN RADIO!
NOW AT DD MODS!
$329.99
Package includes
1- OCAR radio
1- Standard GM Harness
1- 1.5 to 1.0 dash kit
1- GM Antenna Adapter
SPECIFICATIONS
OCar is the first full-integrated head unit specifically designed and made for iPhone. It’s patented technologies enable you to control all standard car stereo functions using the iPhone touch screen, while allowing horizontal and vertical access, so that all iPhone applications work as intended in your car. You can listen to your entire iTunes music catalog, make a hands-free phone call or synch a Bluetooth headset, access your favorite iPhone apps for the car (GPS, Pandora, etc.), or listen to your favorite local radio station.
Features
Phone orientation (90º), tilting (15º) and extraction
Compatible with iPhone 3G, 3GS & iPhone 4
Audio peripheral controlled by the iPhone and compatible with all its apps
Access to all car radio audio, video and theme features
"Sound" and "Radio" app available as a free download at the Apple store
iPhone charging
Complete use of Apple’s touch technology
Introduction of a real radio unit for iPhone
Intuitive station search mode and audio settings
2 protective cases provided (iPhone 3G, 3GS & 4)
RADIO SPECIFICATIONS
RDS tuner with AF & TA function
Automatic or manual station search and programming
24 programmable radio stations (18 FM & 6 AM)
AM frequency range: 522 KHz - 1620 KHz
FM frequency range: 87.50 MHz - 108.00 MHz
Local or national programme reception (Local/DX)
AUDIO/VIDEO SPECIFICATIONS
4 x 55W built-in amplifier (max @ 4 Ohms)
Signal/noise ratio > 95 dB (20Hz>20KHz)
Balance (L/R) and fader (F/R) settings
Low (60Hz), mid (1KHz) and high (12KHz) frequency calibration
Subwoofer output level check (RCA)
3 RCA outputs (front, rear and subwoofer)
1 RCA video output
Built-in Bluetooth hands-free kit with external microphone supplied
MISCELLANEOUS
ISO (Full Europe) connect power supply and loudspeaker cables
Detachable security element (delivered with transport case)
Button backlit in white
Extractible (45 mm) and tilting (15°/360°) base
Device dimensions 187 mm x 58.5 mm x 106 mm
Device weight: 1100 g
Radio App
Controls the OCar’s built-in tuner.
This app can be downloaded free from the iTunes store.
Sound App
Calibrates the OCar’s built-in amplifier. This app can be downloaded free from the iTunes store.
we were allocated 6 of these and have 3 left in the first couple hours
more coming in around the 19th of September for those who miss out on the first batch
Ipad operates different than the iphone so not yet
there is talk of an Adroid version as well
problem with Android is there is 3 different platforms they use for operating systems so its hard to make something direct for the Android
These are brand new and we have not put them in anything but a C5 Corvette at this point
I can do 299.99 shipped for a package for you if your interested
will check on SW controls that would add 59.99 to this
Dennis
