Wiring a Kee sail panel sub to the factory harness
Old 09-16-2011, 11:16 PM
Double Aught's Avatar
Default Wiring a Kee sail panel sub to the factory harness
The factory monsoon harness has four wires, two + two- . Kee subwoofer has one + and one -. Do I wire the two +'s and two-'s together and hook it up or do I use just one set of + and - ? The rest of the system is installed. Thanks.
Old 09-17-2011, 06:23 AM
Ungrounded Moderator
WhiteBird00's Avatar
This must be the CDT subs because the Bazookas have four terminals. DO NOT connect both pairs to a single pair of terminals... just pick one pair and use that (it doesn't matter which pair because they both carry the same signal).
Old 09-17-2011, 10:57 AM
Thanks.
Old 09-17-2011, 02:27 PM
Ghostintheshell's Avatar
Post pics of your install!
Love to see how it's done. I'm ordering the kee package too!
Old 09-17-2011, 05:04 PM
Ahh, prolly should have. It is really a straightforward thing. It is almost 100% plug and play. All you really need are connectors, a modicom of tools and know how. The only modification I had to do was with the door speaker shell. I had to notch it so the speaker spade connectors would clear. The other thing was I had to drill new holes for the sail panel speakers as they were an RCH off, again no biggie. The only problem I have now is the driver side door speaker is buzzing, may have to send it back.
