Check out these mini amps from Rockford Fosgate!
Old 09-22-2011, 03:57 PM
Closed ex-Sponsor Account
DOUBLEDMODS's Avatar
Default Check out these mini amps from Rockford Fosgate!
I just got some of these amps in today. WOW
They are really small! Check out my cell phone on top of them to give you an idea in size!
These will easily fit below the seats of your car.
PBR300x4
PBR300x1
$149.99 each!
Click here for more info and ordering
The PBR300X4 is a full-range 4-channel amplifier designed for stereo front/rear systems that requires little space.
The BRT (Boosted Rail Technology) is an ultra efficient design that generates 300 Watts of power!
The BRT also has a variable hi-level DC offset turn-on circuit for easy installation into any OEM system.
Details:
4-channel car amplifier
75 watts RMS x 4 at 4 ohms
non-bridgeable, 4-ohm stable per channel
CEA-2006 compliant
Boosted Rail amp technology
Dynamic Thermal Management cooling system
selectable high- and low-pass filters (80 Hz, 12 dB/octave)
differential-balanced inputs eliminate noise from your vehicle's electrical system
preamp and speaker-level inputs
10-gauge power and ground leads and a 30-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 30-amp in-line fuse between the distribution block and the amplifier is recommended
dimensions: 6-15/16"W x 1-9/16"H x 4-5/16"D
The PBR300X1 is a mono amplifier designed for a subwoofer system that requires little space.
The BRT (Boosted Rail Technology) is an ultra efficient design that doesn't even use a switching power supply to generate its 300 Watts of power!
Product Features:
Punch Series BR Mono Block Car Amplifier
RMS Power Rating:
4 ohms: 75 watts x 1 chan.
2 ohms: 150 watts x 1 chan.
1 ohm: 300 watts x 1 chan.
Max Power: 924 watts x 1 chan.
Ultra compact chassis
Remote bass level input (remote level control sold separately)
LED power and protect indicators
Mono channel operation
Optional PEQ provides 0dB to +18dB @ 45Hz
High level speaker input connection
Low level RCA input connection
NOMAD protection circuitry
Convection cooling design
Extruded aluminum heat sink
Input sensitivity:
Low level: 150mV-4V
High level: 400mV-11V
Variable DC offset sensitivity
Built-in 12dB/octave Butterworth crossover
Crossover frequency: 35-250 Hz
Frequency response: 20-250 Hz
Damping factor: >200
CEA-2006 compliant amplifier
Dimensions: 6-3/4"L x 4-1/4"W x 1-1/2"H
10 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Old 09-22-2011, 06:06 PM
elwood2's Avatar
Wow, that's pretty small!
Old 09-22-2011, 06:33 PM
Camaroking1996's Avatar
Anyone use them yet?
Old 09-22-2011, 06:52 PM
I just got them today
I am converting our shop truck in a 2000 Durango over to double din and thought I would try these out
I still like the Kenwood XR series and the ARC Audio mini amps the best
Digital Designs has a new 5 channel mini amp coming out too
125 x 4 and 1 at 800
Old 09-22-2011, 06:55 PM
elwood2's Avatar
Damn, any dimensions on that beast?
Old 09-22-2011, 07:35 PM
I dont have the specs for the 5 channel
but here is the 4 channel
should be close
Dimensions - inches 2.07 x 11 x 6.9
Also
Digital Designs will be making product for us to our specs for you guys as well.
Old 09-22-2011, 08:00 PM
How does the ARC mini amp perform?
Old 09-22-2011, 08:11 PM
ARC mini amps are awesome
Highly recommend them
The XDI or KS Series
We sell alot of them in our Corvette speaker packages.
Once we get the new 6.5 DVC 4ohm subs being made for us for you guys your going to see alot of new speaker packages coming using the ARC mini amps, along with the Kenwood XR series
The new stealth boxes are in production now and we will be sending them to Digital Designs for a sub made to best perform in the box as well.
We do so much with the C5, C6 Corvette and Viper owners now. Just working on finalizing special deals for speaker packages you guys are going to love.
Old 09-22-2011, 08:14 PM
And a pic to show how small the RF amps are
MAke the ARC look huge
even with them being small
Old 09-22-2011, 08:18 PM
TruBloodTransAm's Avatar
I wonder how these are in size compared to the stock delco amp.
Old 09-22-2011, 09:37 PM
95TAJade's Avatar
We've got the new RF Boosted Rail amps on our "Wall of Bass" display at the shop I work at...they get down for such a small package. We're running 16 RF P1 12's off one of those PBR 300.1! And it gets down!
Old 09-25-2011, 05:12 PM
So would u say these RF mini amps are worth the money?
Old 09-25-2011, 05:17 PM
for a mini amp at this price
yes
Old 09-25-2011, 05:27 PM
Would it fit under the front seat of an FBody?
Old 09-25-2011, 05:45 PM
easily
imagine a 4 x 6 picture thats just shy of 2 inches tall.
thats how big this is
Old 09-25-2011, 05:50 PM
wow dam
Old 09-25-2011, 09:04 PM
bad_408_vert's Avatar
I'm in, will give you a call tomorrow afternoon.
Old 09-25-2011, 10:02 PM
I will be there
I am usually on the phone most of the day so if I dont answer just leave a message and I will call you back!
608 568 3011
Old 09-25-2011, 11:12 PM
KJZ28's Avatar
Wow this is awesome!!! I will have to show my bro this hes looking for something like this!
Old 09-25-2011, 11:14 PM
createnit's Avatar
crazy!
Quick Reply: Check out these mini amps from Rockford Fosgate!
