Kill switch to cigarette lighter possible?
Old 10-11-2011, 04:29 AM
benoh's Avatar
Default Kill switch to cigarette lighter possible?
Has anyone tried or would know if it be possible to wire up a kill switch to my cigarette lighter and still have it functional as a 12v source?
Instructions, tips or details would be greatly appreciated.
Old 10-11-2011, 06:07 AM
shoemike's Avatar
It's possible.
I've used this.
Old 10-11-2011, 07:48 AM
dragonrage's Avatar
Sure... just cut the positive wire (the one in the center) and put a switch in-line with it. Wires will need extending. The switch should be rated for at least as much as the fuse, which is either 10A or 15A.
Old 10-12-2011, 08:32 AM
Save the manuals!
wssix99's Avatar
I've turned my lighter in to a switch. Push the lighter element=on, pull it out=off. The can't use it as a power source.
If you have to keep it as a spare power port, then shoemike's device looks the way to go.
Old 10-12-2011, 09:48 AM
bad_408_vert's Avatar
Shoemike - how exactly does that external adapter work for op's purpose?
Is the external adapter just for a power source & switch on it is a kill switch?
Quick Reply: Kill switch to cigarette lighter possible?
