A little help with Alpine CDe1245xm and installing ASWC
I went to hook this up. First off there is no SWC hole on the back of this head unit. Nor is there a wire for the SW on the back of the wiring for the head unit.
Anyone have any input on where I should hook what to make this work? Obviously I will have to use the adapter for the SWC but am unsure of which wires to use since it only specifies which ones to use if you are using 2 other brands.
Any help is appreciated
this is on a 2002 T/A
