alarm on 2003 silverado
Old 03-14-2004, 12:22 AM
bigpappasz28's Avatar
Default alarm on 2003 silverado
Just wondering if someone has installed a remote start alarm and window roll up on a 2003 silverado?Where can i get a wire diagram on that truck,i have the alarm and was going to install it my self due to shops charge alot to install,ive don it before but they say the 2003 silverado has diferent wiring than older models,need wire diagrams
Old 03-14-2004, 03:16 PM
anyone know where?
Old 03-14-2004, 08:09 PM
need help?need wiring digram
Old 03-15-2004, 08:04 AM
SSactionLs1's Avatar
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White V6 Coil, If V8 at Any Coil, 1 Cylinder Setting
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Light Blue (+) Light Switch
Head Lamp Yellow (+) Light Switch
Factory Disarm Light Green (-) Keyless Module
Door Trigger Tan DR. (-) Light Blue Passenger's Module below Steering Column
Door Lock Light Blue (+) Keyless Entry Module below Steering Column
Door Unlock White (+) Positive Trigger
Driver's Lock Gray Driver's Kick Panel
Driver's Unlock Tan Driver's Kick Panel
Passenger Unlock White Driver's Kick Panel
Horn Wire Black (-) Steering Column
Windows Up LF=Dark Blue, RF=Light Blue
Windows Down LF=Brown, RF=Tan
Old 03-15-2004, 05:28 PM
where did you get this info?do i need any special modules?
Old 03-19-2004, 04:50 AM
you will need a 555L or 555T which is a module that emits the signal from your key to the ign. And i believe your door locks require a 5 wire (relay)
Old 03-19-2004, 04:08 PM
do you know where can i get the digram to show where the wires are at on the 2003 silverado?Ive herd of directtech but you need a pasword to get any info
Old 03-20-2004, 01:44 AM
www.the12volt.com
Old 03-24-2004, 03:41 PM
thanks for the site,but you need a password to get the wiring diagrams on that site.Do you have a password?
Old 03-24-2004, 04:36 PM
FILE's Avatar
Very good info since I am the market for an alarm. I was wondering the same thing about the password.
Old 03-25-2004, 12:52 PM
Default any one know
does any one have the a password to get in the site?
Old 03-25-2004, 01:28 PM
unredeemed's Avatar
Taken from website home page
Joining is free and simple, and includes access to our vehicle wiring database.
Old 03-25-2004, 01:41 PM
Does anyone have the password to the site to get the diagram?
Quick Reply: alarm on 2003 silverado
