Can I run a 10" sub off of the factory monsoon amp? Without an additional amp.
Old 01-02-2012, 03:30 PM
99wssixm6's Avatar
Default Can I run a 10" sub off of the factory monsoon amp? Without an additional amp.
I know it sounds lazy and dumb but I want to know if I can run a sub without running a new amp. Basically use the Monsoon amp to power it. Obviously it would be way under powered but would it still produce some bass. Im not looking for something you can hear across the street but something to supplement the sail panels.
Or option two, disconnect the sail panels and only use the amp.
Just thinking and looking at Kee Audios, box/sub deal.
Thanks
Old 01-02-2012, 04:14 PM
Ungrounded Moderator
WhiteBird00's Avatar
In a word... no.
Old 01-02-2012, 11:35 PM
99wssixm6's Avatar
Thats exactly what I thought but I just wanted to verify.
Thanks
Old 01-03-2012, 08:12 AM
dragonrage's Avatar
You actually can, and it will work better than the stock 6.5"s... but not well enough that I would recommend it.
Quick Reply: Can I run a 10" sub off of the factory monsoon amp? Without an additional amp.
