question about the wire from the hid ballast to the hid bulb
i have a question...
1. Is that wire replacable
2. Are all ballast connections the same
3. If anyone knows were i can the wire from the ballast to the hella 57000 id really apreciate the help....
I bought a kit a few weeks ago and they glare so bad i want to go to projector style lenses and i want to use the ballest i already installed and hook it up to the hella 57000 setup....
Ummmm my kit has bulbs that have 2 wires coming out of the ... The Hella 57000 has only one female connection ... I need a wire that goes from the ballest to the new bulb?..... Does that make any sense?
Copy & Paste Moderator
The Hella 57000 is a 60mm projector that uses a 9005 bulb. This is the same projector in the BLS kit.
If you currently have an aftermarket HID kit, all you need is new bulbs. Almost all currently sold aftermarket HID kits use the same 2-connector setup and the bulbs are interchangeable.
OEM HID ballasts are different and use a single larger connector.
Some older HID kits used different connectors.
aftermarket, ballast, black, bulb, bulbs, connectors, female, hella, hid, interchangeable, kit, ls1tech, same, technology, wire
