Curtesy light won't turn off, help!
Old 03-20-2004, 09:36 PM
Larry's Avatar
Default Curtesy light won't turn off, help!
Where is the dimmer located for the curtesty light in the rear view mirror. Mine started flicking when I hit a rough spot in the road now won't turn off at all.
Old 03-20-2004, 09:45 PM
wrencher
wrencher's Avatar
You mean the map light?
Is the switch screwed up??
If you have to, disconnect the rear view mirror harness.
Old 03-20-2004, 10:12 PM
Larry's Avatar
Yes, the map light won't go off. The switch turned it on fine when it was going off so I don't think it's the switch. The way it was flashing on over bumps seems to me indicated it the dimmer portion causing the problem.
I suppose disconnecting the harness would be better than pulling the fuse. Would rather fix it.
Old 03-21-2004, 01:40 AM
WS6 RULES's Avatar
Dimmer switch is wheel by headlight switch, at least on 2000 and now my 2002.
Old 03-21-2004, 05:42 AM
Larry's Avatar
I meant the part that controls the light delay after shutting the door. I don't think that is controlled with a switch.
Old 03-21-2004, 12:46 PM
wrencher
wrencher's Avatar
The time delay is a BCM fuction, this looks like a problem that is gonna need to be diagnoised.
Old 03-21-2004, 01:09 PM
Larry's Avatar
BCM function? Sorry but what is that?
Old 03-21-2004, 01:38 PM
wrencher
wrencher's Avatar
Body control module, if your problem is not in the rear view switch it prolly lies here & will have to be found........
Old 03-21-2004, 01:46 PM
Larry's Avatar
Thanks! Until I can get the problem traced down I'll have to leave the fuse out to prevent my battery from draining.
