Easiest way to disable door dinger?
Ungrounded Moderator
No, chime is in the BCM. Unlike newer vehicles, replacing the HU will not affect the chimes. Disconnecting the light green wire in position C14 of the blue 32-pin connector at the BCM will eliminate the key-in signal. It will not eliminate chimes for seat belt, headlights, etc.
Save the manuals!
Is the problem that you don't like the chime while you are working on the car?
I like the chime as its saved me many times from locking the key in the car during normal driving, etc.
When I work on the car, I just take a screw driver and press down the door latch to make the car "think" that its closed. When I'm done, I just put the screw driver back in, pull on the door handle, and then flip the latch back open so I can close the door.
Save the manuals!
I'm sure the NHTSA wouldn't approve of this, though.
