Thump when system turns on, turns off, and when selecting sources. - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 03-11-2012, 09:29 PM   #1
Avengeance's Avatar
Default Thump when system turns on, turns off, and when selecting sources.
I recently added a Kicker ZX 750.1 to my system to power a single JL 10W3. Im running it in 4ohm to the single sub. There is also a JL 300/4 running my mids/highs... and before the kicker amp the 300/4 ran the whole system including my sub. Never had this issue before.
I just installed the amp... and ran a new RCA from front to back to the Kicker amp. Ive noticed I get a loud thump from the sub when turning on, turning off, and also when switching from CD - line in - radio - etc. Each source produces the thump.
Ive read up online so I have some things to check but thought Id ask here in the meantime.
Couple things... the new RCA isnt the greatest of quality. The remote turn on is routed right next to the Kicker amps power wire, literally on top of it.
Oh also... the amp has a feature to turn on by 12v remote, DC power from the 12v in, and also RCA input. It does this with all 3 settings.
Thanks!
Avengeance is offline   Reply With Quote
Old 03-11-2012, 09:45 PM   #2
V8ImpSS's Avatar
what head unit?
the noise from turning on would be because the amp turns on too soon, before the source...but it sounds like a different problem, psooibly related to the order in which things are turning on or off
try disconnecting the 12v trigger and turning the amp on my manually touching a wire from the fat +12v to the remote trigger AFTER EVERYTHING ELSE IS ON
but that's a strange problem with it making a noise when switching sources
V8ImpSS is offline   Reply With Quote
Old 03-13-2012, 12:44 AM   #3
little off topic but how does ur w3 sound in ur car
CaliboyTA is offline   Reply With Quote
Old 03-13-2012, 12:49 AM   #4
jonnyv713's Avatar
Things to do....
Check all your grounds. They should be to bare metal, and short as possible. HU ground should not be using the factory ground. Ground it to the dash frame.
RCAs should not be ran next to your power wires.
If that doesnt work, ground your RCAs to the chassis of your HU.
If all that doesnt work, use a ground loop isolator.
(non-sponsor link removed)
Last edited by WhiteBird00; 03-13-2012 at 08:33 AM. Reason: non-sponsor link removed
jonnyv713 is offline   Reply With Quote
Old 03-13-2012, 02:47 PM   #5
Avengeance's Avatar
Caliboy... this is actually in my truck. Sounds pretty good in my truck, I bet it would sound even better in my F-body back in the t-top well.
jonnyv.... thanks for the input. Im going to try to re-route everything. I do have some wires closer together than Id like them to be.
Old 03-13-2012, 04:16 PM   #6
oh ok just wondering. i bought myself a used jl stealthbox with 1 10 w3 but the sub is blown. i dont know if i should get something else or stick with the new version of the w3
Related Topics
Thread Thread Starter Forum Replies Last Post
Recommendations for JL JX500/1D and JL Stealthbox install in 02 WS6 drain89 Stereo & Electronics 7 10-28-2016 06:21 PM
Installing after market amp/sub into 2006 cts regulater7 Cadillac CTS-V 2004-2007 (Gen I) 6 11-13-2012 03:07 PM
Kicker DX500.1 sub amp kills FM reception MBC Racing Stereo & Electronics 2 07-30-2012 09:47 AM
RCA Input for amp from Monsoon?? how ??? Nastyc4 Stereo & Electronics 7 05-18-2010 03:57 PM
Turn off thump, 2 Amp's, New Kenwood HU, MYTFASTSS Stereo & Electronics 15 05-22-2009 09:44 PM
Tags
51k, 7501, amp, audison, av, gas, kicker, logs, password, rick, synergy, thump, tune, turn, turning, voce, whenturn, zx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
