Loose connection for power to headlight - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 03-19-2012, 07:42 PM   #1
Default Loose connection for power to headlight
The connector for my headlight keeps falling off of my headlight. The light works perfectly but I keep having to remove the bezel to reconnect it.
It's so bad that it doesn't even last longer than a few miles. I used to have to fix it once every 2 months.
I'm thinking of the following options:
  • If I replace the headlight maybe the connection will stick?
  • Should I replace the connector itself?
  • Should I use some kind of adhesive or just a rubberband to strap it down?
What do you think? Anyone else have this problem?
This problem has been slowly getting worse.
kevinbushman is offline   Reply With Quote
Old 03-20-2012, 08:06 AM   #2
Save the manuals!
wssix99's Avatar
This is for a Firebird, right? You may try a search. There have been other threads on this.
I recall when I had the problem - I just had to bend the two prongs on the headlight bulb in a bit and the connector stayed put.
wssix99 is offline   Reply With Quote
Old 03-20-2012, 08:21 AM   #3
Quote:
This is genius. I'll be trying this. Thanks!
Yes, for Firebird. I did search though I might not have been using the correct search terms. I kept getting results for the motor.
Old 03-22-2012, 01:04 AM   #4
Copy & Paste Moderator
VIP1's Avatar
Are you using the newer style sealed beam bulbs with the big white silicone cap on the back? If so, you can do what I did.
1) bend the bulbs prongs slightly inward to improve contact and add tension
2) use a screw through the existing hole in the middle of the bulb connector to screw into the white silicone cap
VIP1 is offline   Reply With Quote
Tags
bent, car, coming, connection, connector, fix, fixing, headlamp, headlight, headlights, loose, loosr, ls1tech, power, prong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
