gauge cluster and radio problem - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
Thread Tools Search this Thread
Old 03-21-2012, 07:30 PM   #1
ozzman98's Avatar
Default gauge cluster and radio problem
so i have a 1998 trans am an had some more work done at a shop (very well known shop, but not naming names) an after the car was finished my radio, milage display and trunk release no longer work. and im not certain if my dummy lights on the cluster itself work either. i didnt notice that these things didnt work until months after the work was done since i never drive the car so dont really wantto go bitching at the shop. if anyone has any ideas please let me know. i have another pcm that im going to try an will check the wiring harness down by the pass. kick panel to make sure it got plugged in all the way. other then those two things i am completly stumped. thanks
ozzman98 is offline   Reply With Quote
Old 03-22-2012, 07:30 AM   #2
Save the manuals!
wssix99's Avatar
Fuse?
wssix99 is offline   Reply With Quote
Old 03-22-2012, 04:12 PM   #3
ozzman98's Avatar
yea i checked all the fuses an relays. everything is good.
Old 03-22-2012, 04:46 PM   #4
Save the manuals!
wssix99's Avatar
I have to ask... Did you check to make sure the techs working on your car just didn't turn down the interior light dimmer switch? That will cut all of those lights off.
If the dimmer is up, you might check the electrical at the switch. It could be bad.
Old 03-22-2012, 06:17 PM   #5
V8ImpSS's Avatar
trunk releases can go bad in cars with big bass...I've replaced mine twice now in the Impala
as far as the lights...it could be the dimmer wire that goes to the factory headunit, a new aftermarket one would most likely not have an input for the dimmer, try grounding it
V8ImpSS is offline   Reply With Quote
Old 03-27-2012, 10:51 PM   #6
ozzman98's Avatar
yes the dimmer switch works just fine.
Old 03-28-2012, 08:19 AM   #7
Save the manuals!
wssix99's Avatar
So, the dimmer switch dims all the lights, just not the ones that are out?
Old 04-03-2012, 03:18 AM   #8
ozzman98's Avatar
mo lights were out. just the numbers wouldnt light up on odometer an the radio wouldnt power on. but it is fixed now. i found the the connection on the power accessory fuse was bad. put a new piece of wire an connector in an now everything works great. so a lil trick was learned. pull that fuse an u wont rack up miles on ur car. bud u wont have a radio either unless u hardwire it. but atleast it all works again.
Old 06-23-2012, 05:26 PM   #9
I too had the SAME exact problem as you. No radio, no odometer, and no hatch release with fob or button under the dash. I looked high and low for 3 hours thinking it was a connection problem I had pulled loose some where. I checked all of the power reading at the radio hatch and had 12.3 volts. I was stumped. I looked on wire diagrams and thought it was the courtesy fuse since that linked all together from what I read. I tried searching for this problem on line and i'm really glad you had the same problem and had a fix. I went to the power acc. fuse pulled it out and it was blown. Thank you! Now my trunk pops and radio is blasting and odometer works.
Bighunt is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Gauge cluster not working BlackedOut LS1 Stereo & Electronics 4 08-19-2015 03:46 PM
2002 Trans am Instrument Cluster Issue- Gauges no working! marunos General Maintenance & Repairs 10 08-02-2015 12:58 AM
Cluster goes haywire when revving? xXSilencerXx General Maintenance & Repairs 7 07-24-2014 11:55 AM
radio not working matt01ws6 Stereo & Electronics 4 05-21-2014 09:03 PM
Dead gauges and electrical gremlins on 99 Camaro superbee_68 Stereo & Electronics 6 02-19-2014 06:08 PM
Tags
1998, 1999, 98, camaro, cluster, dimmer, firebird, gauge, instrument, issue, photo, problem, radio, short, trans, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
