HID Fog Light help
Old 04-05-2012, 05:12 PM
mike.warrenws6's Avatar
Default HID Fog Light help
Im trying to replace my Fog Lights in my Trans Am. 880's i believe. i was reading up on a 4 year old post on them but i cant find the same dealer and i dont want buy the wrong HIDS. They supposidly plug in play etc etc.
If you have them can you share a link and w.e info ill need. thanks!
Old 04-05-2012, 05:47 PM
95LTXZ28's Avatar
I know a ton of guys use DDM tuning. I just ordered from them and everything works well and fits nice.
Old 04-05-2012, 06:09 PM
can you give me the link to exactly what you orderd?
Old 04-06-2012, 08:51 PM
99fbodyTA's Avatar
oh god hid's should be outlawed....always blinding me
Old 04-07-2012, 12:11 AM
02CamZ28's Avatar
I got some off ebay xentec i believe they work great on my camaro i think they are 881 which are prety much the same as 880 dont quote me but ya $32 shipped plug and play
Old 04-17-2012, 09:43 PM
Chanson's Avatar
Hey i havent replaced the fog lights on my 95 ws6 I recently got it had a 99 firebird before and one of the foglights are out how do you replace it do u pull from the front or do u need to come in behind it i just dont wanna break the lense by pulling on it you know thanks for the help! anyone in the nebraska area wanna race hit me up
Old 04-17-2012, 11:22 PM
Streetlegal?'s Avatar
Here is the links
This is the normal size ballast kit
(non-sponsor link removed)
This is the slim ballast kit
The slim ballasts have a better design but the regular ones are fine too.
Just select the drop down boxes and fill them out as:
Wattage: 35Watt (55watt is too much for the small housing and it will get too hot)
Bulb Type: 880/881/898/899etc
Bulb Color: whatever you want
Then leave these blank because you don't need them
HID Harness
Error Eliminator
Adaptor cables
Mounting Brackets
You can also use this for later use to check bulb sizes
http://www.sylvania.com/en-us/applic...n.aspx#fldYear
Old 04-19-2012, 02:17 PM
TrexAudiS3's Avatar
I bought kensun Xenon kit from amazon 60 bucks, is plug n play and doesnt blind the other drivers. I ordered 4300K (oem in Audi, Mercedes etc.). I have installed the kit 2 weeks ago and i dont have any problem.
Firebird Trans Am 1997 fog lights 880 bulbs 35 watts.
Old 04-25-2012, 06:49 PM
firemech21's Avatar
I am using DDM 6000K HID's in my T/A and they have been great so far.
Old 04-25-2012, 09:43 PM
Tram's Avatar
If more guys would take the time to do proper installs, you wouldn't be blinded..
Old 04-25-2012, 10:31 PM
Most people just take them and slap them in and don't properly aim them and that is why. If you take the time to aim them since the output pattern and light focus is different is isn't that bad.
Old 04-25-2012, 10:47 PM
firemech21's Avatar
I agree with the above 2 posts. After I finished my install first thing I did was pull the car out of tha garage get and get my beams aligned properly and havent had any oncoming traffic flash their lights at me yet.
Old 04-26-2012, 01:14 AM
WS SIK6's Avatar
I don't mean to hijack the post but I had some issues when I installed my hid kit on my fog light housing, I had them on for about 3 days then I noticed that the weren't aligned while I was drivin so I pulled over and checked them out only to notice that my fog light housing was melting with the heat of the hid bulbs, anybody have the same or a similar experience?
Old 04-26-2012, 11:07 AM
What wattage ballast did you purchase with the HIDs? You shouldn't use a 55W ballast (or 50W if you are ordering from The Retrofit Source) in the foglight housing due to the size with just an HID bulb.
Old 04-26-2012, 05:28 PM
WS SIK6's Avatar
I'm not sure what was the wattage but I will check when I get home, what kind of hid kit am I supposed to use?
Old 04-26-2012, 10:23 PM
What do you mean what kind? Like brand? If you are planning on getting a new kit make sure you get a 35W kit otherwise they will be too hot for the small housing.
Quick Reply: HID Fog Light help
