What type of speaker is this?
Old 04-12-2012, 06:37 PM
Skraight's Avatar
Default What type of speaker is this?
I was wondering if anybody knew what type of speaker this is?
I don't have any tools to take the door panel off right now to check the back.
The sound system sounds kind of shitty and I'm wondering if its because these are cheap or maybe they are the wrong type, i.e. 4ohm instead of 2ohm.
I also checked the ones in the sail panel and they are the exact same.
Sorry pictures pretty big. Not sure how to resize it.
Thanks,
Old 04-12-2012, 06:50 PM
Skraight's Avatar
Figured it out, they are Alpine Type-S with the covers removed.
And they are 4 ohms. Hmm.
Old 04-13-2012, 07:28 AM
Ungrounded Moderator
WhiteBird00's Avatar
The impedance makes very little difference and it only affects volume not quality of sound. The problem is likely the fact that they are the wrong types of speakers for the system (assuming a Monsoon system) and could also be wired incorrectly. For example, any coaxial speaker will sound bad in the sail panels because the amp is designed for subs there and only provides low frequency signal.
Old 04-13-2012, 08:57 AM
Skraight's Avatar
You are right, he just wired the speaker up and left the wires hanging for the tweeter it seems.
He also put these coaxials in the sail panels so looks like I have some work to do.
