locking the car - LS1TECH
Stereo & Electronics Audio Components | Radars | Alarms
locking the car
Thread Tools Search this Thread
Old 04-18-2012, 02:21 PM   #1
Z28-4Ever's Avatar
Default locking the car
when i use my key to lock the car, every few seconds my alarm will beep then stop, then start beeping again, but when i manually lock the car it doesn't do it. can someone help me out with what the problem is?
Z28-4Ever is offline   Reply With Quote
Old 04-18-2012, 02:30 PM   #2
bad_408_vert's Avatar
Remove the shock sensor in the hatch, by the spare tire.
Removing it doesn't disable your alarm / keyless features.
Its going crazy because of moisture build up.
You can leave it open and set it to dry but it might just have moisture build inside it again.
bad_408_vert is offline   Reply With Quote
Old 06-07-2012, 03:24 PM   #3
Z28-4Ever's Avatar
well i took it out of the back to see if there was any moisture in it and it looked fine, so i hooked it back up and locked it with the remote and it beeped once and hasn't gone off since but it still beeped.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
